Re: 120HP Force - 1992 I need help!
One thing I've had problems with that caused this propblem,was play in the carb linkage.<br />My force is a samller engine,but it cause it to idle funky.Sometimes it was fine,others, it just didn't idle high enough.<br />Check the linkage between the throttle stay and the actual butterfly arm, while someone moves the throttle back and forth (engine not running).<br />no wiggling,play or travel should be noted between throttle stay and butterfly arm.<br />If there is play, most times it can be repaired with a screwdriver,sometimes not.<br />Good luck.<br /><br />------------------<br />I'm no expert, but I DID sleep at a Holiday Inn last night!
