Re: force engine runs hot
Hi Chashare,<br />You either have a leaking head gasket or a<br />bad broken water pump impeller.<br />Pull off the plug wires and wrap a rope around the flywheel and pull it over to see<br />if one cyl rocks over easier than the other.<br />The easy one may be bad.A compression tester is best.<br />You probably have a bad waterpump. Take the LU off,4 bolts. Disconnect the shift and the <br />cover you see when it drop down contians the<br />impeller.<br />...have fun...corm
