James Blake Jones
- Dec 9, 2001
- 3
Listmates,<br />I have a Rendova 14 that I acquired used with a Force 50 2 cycle outboard. The outboard leaks water into one cylinder, the head gasket is OK, and now the hydraulic trim does not operate downwards, so unable to lower the motor into the water. Wiring seems to be OK and switch. Relays seem to work. Suspect the hydraulic unit itself. Could repair, or repower. If repowering, what do you think are the best brands of outboards? Would a four-cycle be slower than a two cycle? The boat does not have a tag showing maximum allowable weight, and I don't know what the Force weighs. All thoughts appreciated.<br />James Jones<br />Seattle
