sstirling1
- Oct 26, 2001
- 3
I have a 9.9 1994 force engine that won't freakin start.. I ripped apart the powerhead to get to the rings (over heated) I put it back together (several times) I now have 100% compression, spark..(pretty sure there is no timing adjustment on the engine just a magnetic flywheel and coils) I had trouble getting the fuel to come out (took it to a mechanic told me the secondary pressure was low i.e I din't seal the power head correctly) now it is spurting out a couple of feet at least (when not connected to the carb) The carb is fine(checked by the mechanic) PLEASE HELP ME!!!!!!!!!!!!!!!<br />thanks <br />scott sstirling1@aol.com
