Re: trim/tilt will not lower
Not neccessaily a relay. Mine would not raise, but would lower, I raised mine when I wanted it up by going under the cover, and unpluging the green, and blue wires that controll the trim, and swtching them blue to green, and green to blue (as with DC currant all you do to reverse the motor, is switch the polarity), then when I pushed the down button, it instead went up, then switched the wires (plug-ins) back to get it down. I now have a spare relay, as I purchased a new one, and found out that is not the problem, the problem is in the switch, which is one bugger to get into, so I guess I will wait till this winter to tear into the switch in the control handle, switching wires in the meantime to raise the motor if I want it up. I have also considered cutting the wires before they get to the controll handle, and wireing in a new two way switch on the dash board to reverse polarity, and work the trim/tilt.
