sea king 12 hp trouble starting
giveithell321
my engine has the montgomery ward name on it from where they bought the name, it also was made in ohio(i can't make out the city name but it starts with a "t" i believe), also it has 2 cylinder.when the starter cord is pulled there is no spark to the plug when u hold it to the block. the coils are cracked and i believe i read that if that they'er cracked that they can leak high amounts of electricty.would any body now what is wrong, should you have any idea please respond. <br /> sea king model # 15gg-9018
Mod2
Re: sea king 12 hp trouble starting
I'm going to move your post over to the "Other Outboard" forum. You'll get some good advice over there on your engine problem.<br /><br />And yes, if the coils are cracked, they can leak to ground and cause you to have no spark. Best advice is to replace cracked coils.
