Gamefisher 9.9hp - have to pump gas bulb in order to keep it running
allegiance
I have an early 80s Sears Gamefisher 9.9hp that runs well but I have to constantly pump the primer bulb on the gas tank to keep it running. Any suggestions?<br /><br />Thanks, John
crazy charlie
Re: Gamefisher 9.9hp - have to pump gas bulb in order to keep it running
Make sure the vent on the gas tank is working right or replace the hose and bulb before you tinker with the motor.If thats not it then check the fuel filter.Stick with the simple stuff first.Charlie
allegiance
when the engine is running should the vent be open or closed?
CATransplant
Vent should be open when engine is running.
crazy charlie
On most portable tanks there is a small screw in the middle of the fuel gage that needs to me opened to vent.Charlie
RandyJ
Master Chief Petty Officer
Work from the tank to the carb checking for air leaks, pinched lines, etc. Connections are the most common cause of air leaks. My experience is that fuel pumps are seldom the problem unless they've gotten gummed up from sitting too long and then just running them for a while will frequently dissolve the gummy stuff.
