Hi All,<br /><br />I purchased a used gamefisher over the winter and recently tuned it up and the motor seems to be running fine and the tell tale is showing a steady flow of water when running. My first run with the motor today left me standed about a 100 yards off the dock and I had to use my troller motor to get back to dock. Basically, the motor runs fin, but the drive stopped engaging. Any idea where I should start to try and fix this problem? Also, when the motor runs, is it normal for the water from the tell tale to be almost too hot to touch, even showing a little steam?<br /><br />Thanks for any help with this.
