Re: 55hp F/P bearcat -- themostat
The original Homelite 55 did not have a T-Stat at all. It was a few years into production before this was thought of. I hear the main benefit is to those who boat in cold water, plus the mod the factory did (I think at the same time- not completely certain) is that they made it so the water jacket stayed filled until manually drained, making sure cooling happened even at start up. Furthermore, there was less exhaust erosion inside the lower unit. Not sure that leaving the stat out would undo the other improvements; unlikely that it would. On the other hand, the factory did decide it wasn't a bad idea to have one in there. Bottom line is it is only my wild guess that it will make little difference short term.<br /><br />That said, personally, I tend to agree with JB & DJ & will keep mine in place even though I reside in warm water country. There are a couple good dealers out here in Ca. for parts Adventure Bearcat Marine & Economy 4 Cycle marine. Both can be found on the web if you need a replacement.
