Finally installed the Smart Tabs I bought over the winter. Can't wait to give them a run but I'm wondering where the best spot to remount the Speedo and Tranducer is? Should I mount them inboard or outboard of the tabs? Don't want to cause turbulence b-4 the prop and I wonder how much noise there will be just outboard of the tabs? Any suggestions would be really appreciated!!<br /><br />I also ran into a problem on the install, one of the ears in the actuator socket broke off and now you can pull the actuator off with a little tug!! Hopefully it will stay on when I'm under way. If not I guess I'll be calling Nauticus<br /><br />
