Mounting starting battery on an angle?
Johnshan1
Can I mount my starting battery on an angle?<br /><br />I want to put the battery in the splashwell, which is an angle, roughly a 30-40 degree I would say. I will have it in a battery box.<br /><br />Any issues I should be aware of? I dont see any water splashing over the back (who does?) it has never happened in 3 years so I will take my chances with that.<br /><br />-John
WillyBWright
Re: Mounting starting battery on an angle?
You'll probably expose the uphill corners of the plates to air, sulfating them. Leaking acid is also a strong possibility. Can you construct a platform to allow level installation? Otherwise look into a gel battery.
craze1cars
Agreed, your plates need to be emmersed in water....30 to 40 degree angle will expose some plates and will shorten the life of a conventional lead-acid battery. Occasional tipping doesn't hurt them, but they need to be "usually" level. On the flip side, gel or dry cell batteries can be installed upside-down if you like.
Johnshan1
Darn it, guess I will need to think of another location for it.
rottenray6402
Ensign
If you have enough height the idea Willy had about building a bracket would be the best. A simple metal or wood wedge large enough to mount the battery case on would work fine.
tashasdaddy
had the same problem, extended the bettery cables, a put it under the seat. driller a couple of holes for ventilation. has worked great.
cuzner
If money isn't an issue, an agm battery should be able to <br /> handle that angle with out a problem.<br /><br /> Jim
Texasmark
Just make yourself an angle bracket. Attach it to your boat and the battery to it where it can sit flat. It must sit flat.<br /><br />Mark
jch7450
Yep. be safe build a bracket, leaking battery acid isn't a pretty thing, and will turn just about anything into junk
