Hi, I just purchased a Sears 3 HP (this is printed on the lable on the fuel tank)outboard, model # 217-58540, s/n 104154. It is dark green, air-cooled, with a metal fuel tank attached. I would greatly appreciate someone telling me the age and manufacturer of this motor, and where I might be able to get tune-up parts (I'll check with Sears on Monday). It appears that the propeller is always engaged with the engine - no neutral- is this correct? What oil/fuel ratio should I use? Any other info you have is appreciated.<br />Thanks for your time.<br />Paul
