HELP! I have a 9.9 HP Gamefisher Model 225.581998 or 225.581988, I do not know the year. I was cruising across the lake about half throttle and the prop quit turning, but the motor kept running (Revved up really high). There was no snapping, cracking or grinding sounds before or after. There is no visible sign of damage and the motor will start and run, just not go forward or backwards. I would like to know if this is something I may be able to fix or is it serious and I should take it to a shop?
