crumbpicker
- Aug 4, 2004
- 1
Hi I have a clinton K700 3000 that will not start. It's getting spark, so I took apart the carb, clean as a whissle So I'm guessing that the fuel is not getting to the piston, either through a vaccume leak or a blockage in the jet to the piston. The spark plug should get pretty wet with gas right? Has anybody had any experience with this? I sent away for a manual, and I'm anxious to get this on the water. Oh and it's not froze, can see piston and prop moving when trying the pull start.
