pwiseman
- May 4, 2005
- 207
I have had my boat for three weeks now. I have tested out running with 1, 2, and 3 people with two props and noted the RPMS and speeds.<br /><br />Boat is 14'11" Deep V that weighs about 600 lbs.<br /><br />With me and gear (200+50) I get 6200 RPMs fully trimmed at 29.3 mph. Very slight hint at cavitation in sharp turns, the boat does not fall of plane until about 5-7 mph, the hull does not slap waves in chop and the boat will troll down to less than 1 mph. This is by my standards excellent. The only thing that I want to improve on is hole shot. It takes about 8 seconds to plane with me and some gear. This is a 9.25x12 pitch aluminum prop that came with the motor. It will also plane with two people in about 13 seconds and get up to about 25 mph. My conclusion is this is a good setup for one person, or two average people and minimal gear. I wonder why it strugles with the plane and then gets RPMS to just above the recommended max of 6000. Also the 12 won't plane max load of 750 lbs, so it seems fairly obvious that a 12 pitch is towards too much prop.<br /><br />My guess was that an 11 pitch would solve this, but I was surprised. I purchased a solas saturn stainless 10x11 pitch prop. This causes a small loss of top end speed of about 2 mph. It will plane 1 or two people slightly faster than the 12. It will also plane 3 guys of total weight of 750 lbs which is max rating, but it takes excessive time and requires the guy in front to lean forward. It gets 23 MPH if it planes. Interesting that it will not troll down to less than 2 MPH which is a huge black mark in my book. I also think the prop is a bit off true as it wants to vibrate at RPMs under 800.<br /><br />My conclusion is that I probably need two props one for heavy loads and one for light to average. The 11 pitch stainless solas is off the boat and not likely to go back on. <br /><br />There is a 9 3/4 x 9 7/8 OEM Honda prop availalable, but not an 11. Solas makes an 9 7/8 x 11 aluminum. Thinking that I will purchase the OEM 9 7/8 prop and use it for heavy loads and use the 12 when fishing by myself. <br /><br />It is possible that the SOlas 11 pitch aluminum would be a good all around prop? I am a little gunshy on another Solas, but don't want to jump to conculsions. This is aluminum and a different design than the stainless I bought. I don't normally go out with three people, but I will be taking the parents out in August and will have to travel about 10 miles to the destination. My overall concern is that I want to have a prop on that will plane the boat which seems to push me to the 9 7/8ths. I read several times that diameter does not matter much, but wonder if this is a case where it might be a factor. Thanks in advance for any thoughts on this.
