Re: buc 25hp
There is a coil for each cylinder most likely one coil has failed very common on older OMC based motors.Pull the flywheel and check the coils<br /> I would replace both and clean and check points condencer and plug wires.Also if you dont know its history change the impeller and be sure the fuel system is clean.
