5hp buccaneer
zerop3
Does anyone know where I can find parts for a late 50's to early 60's model Buccaneer outboard. I havent gotten to far into to see what I need but I want to try and locate the points, coils, and condenssers first. Then I would probably need a carb kit. Any help would be greatly appreciated.
JB
Re: 5hp buccaneer
Howdy, ZP3.<br /><br />Post the model number of your Buc. Parts will be interchangable with the same year and hp JohnnyRude.<br /><br />Good luck. :)
zerop3
Re: 5hp buccaneer
Im working on getting the serial numbers and model numbers. Does anyone know if these were good motors. One thing that I see that is interesting is that there appears to be no nuetral or reverse. It seems like once it gets started your off and running.
Fouled Plug
Ensign
Re: 5hp buccaneer
Your motor will be as 'good' as any OMC. Some older engines were forward-only. Takes some forethought before you pull the rope! :D
zerop3
Re: 5hp buccaneer
Okay here is the model number 5S13B and the serial number 661703. I am trying to determine the year and what motor might have parts that would be interchangeable. Thanks
tmcalavy
Re: 5hp buccaneer
you have a 57 buccaneer, built by OMC's generic mfg. division...Gale. Go to the Ask a Member board at this site: www.aomci.org<br />and you'll find all the info you might want, part numbers, etc.
