  #1
Old October 3rd, 2005, 12:37 AM
danie danie is offline
Default Running without oil: 90 Mariner 3 cyl: Corrective action?
Hi AllSo after many years of uneventful boating I am now part of the select many who ran his outboard without 2xoil for appr 10 minutes while towing a skier.Although the motor started making a soft but very audible tinny rattling sound after about a minute of running, it was only after the skier was beached about 9 minutes later that oil was seen pouring out the bottom of the cowling.Closer inspection revealed the oil feeding line to be broken off at the oil pump inlet.I managed to replace the piping and while running back noticed the rattling sound to disappear after about 3 minutes.At home I added a little extra oil to the fuel tank and ran the motor the next day on the water for another 2 hours without any problems or unwanted sounds. It runs and idles as smooth as ever.My question therefore is, what parts inside the motor could have been damaged in what way and are there any corrective actions that can be taken at this late hour to minimise or prevent further damage?ThanksD
  #2
Old October 3rd, 2005, 03:04 AM
lark2004 lark2004 is offline
Default Re: Running without oil: 90 Mariner 3 cyl: Corrective action?
The damage that would be caused by this is usually scored cylinders and pistons. The only way of really seeing this is to remove the cylinder head.Other than that, do a compression test, and check that all three cylinders are within 10% of each other.As far as prevention, when you maintain your engine (grease and clean etc....) each month, check all rubber hoses for any signs of cracking or hardening.
  #3
Old October 3rd, 2005, 03:51 AM
Thanks.Believe it or not, the motor had a $400. major service just 5 months (10 hours) ago at the agents.D
  #4
Old October 3rd, 2005, 04:12 AM
I don't trust dealers, too many times something simple gets missed
  #5
Old October 3rd, 2005, 10:33 AM
LubeDude's Avatar
LubeDude LubeDude is offline
The first thing that goes without oil is the crankshaft and rod assembly. Then the piston area starts to suffer. For whatever reason, the crank seems to go longer without damage than the piston area. You have no way of knowing what damage was actually done without a complete teardown, but you can remove the head and check things out. If your compression test shows everything fine, you may have got lucky this time. "REAL LUCKY".Just for the sake of discussion, what oil were you using [or not using], when this happened?
  #6
Old October 3rd, 2005, 05:45 PM
JasonJ's Avatar
JasonJ JasonJ is offline
Since the reciprocating assembly (crank, rods) is on roller bearings, they are probably okay. The pistons and cylinders could be scored due to scuffing. The fuel/oil mix cools as well as lubricates, the pistons would expand more and possibly make physical contact with the cylinder wall. The gasoline will provide some lubrication on a short term basis. If your motor is still performing the same at the same rpm range, you probably got off wit a bit of cylinder scuffing. Compression check may or may not tell you. Running extra oil won't make up for anything, so you may as well just run your regular ratio, and thank God you were this lucky...
__________________
Project Skanky Beast http://70silverline.250free.com/Skankybeast.html
  #7
Old October 3rd, 2005, 10:49 PM
Thanks guys for the info. Looks like I got away with it this time.LubeDude, Im using Shell Nautilus.
  #8
Old October 4th, 2005, 12:08 PM
ZmOz ZmOz is offline
Quote:
Originally posted by Damdan:Looks like I got away with it this time.
I wouldn't be so sure of that. If you have a removeable head, unlike my motor, it would be a REALLY good idea to remove it and have a look...or at the very least barrow/rent/buy a borescope and have a look. I ran my '74 150hp Mercury for about 10 minutes without oil. After I realized the problem and added about twice the usual oil it SEEMED to run ok the rest of the day, but it DEFINATELY was not ok inside. A total rebuild was required. It is very likely that at least one of your cylinders is in very bad condition...be ready for a total rebuild in the near future.
  #9
Old October 4th, 2005, 12:53 PM
Moody Blue Moody Blue is offline
Get a compression test done to confirm one way or the other. Only takes a couple minutes then you can be confident of your motors condition. Don't panic about something you aren't sure about
  #10
Old October 5th, 2005, 03:14 AM
Will do.Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner 150 still running HOT. rocks Mercury & Mariner Outboards 8 July 10th, 2005 05:54 AM
'95 Mariner 60--running on 2/3 Dman Mercury & Mariner Outboards 2 April 16th, 2004 05:34 AM
Should I leave old but running O/B alone or take preventive action? Tinkerer Johnson & Evinrude Outboards 2 May 19th, 2003 07:14 PM
ROUGH RUNNING MARINER fish52 Mercury & Mariner Outboards 2 July 24th, 2002 06:10 AM
20 hp Mariner running bad gprestridge Mercury & Mariner Outboards 5 May 21st, 2002 03:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
