I have a 1998 Yamaha C115 that will not run over 4K RPM's without the buzzer going off. I can run at 3500 all day with no problems. I've changed the impeller, thermo's, checked poppit valve(replaced spring). I heard it's probably time to pull the heads & clean the corrosion build up. I have a little mechanical skills but worried about trying this myself. How hard is this? Is there a chemical you need to use to clean the salt corrosion, etc.<br />Any help would be greatly appreciated. I'm in New Orleans & it is weeks before a mechanic could even look at this thing. They are busy fixing boats that sunk, rigging new boats for people that lost theirs in the storm.
