sylvanclassic
- Apr 22, 2006
- 7
I have recently acquired a 1994 Sylvan Classic 14ft fishing boat with a 1994 Yamaha 25hp outboard motor(model C25ERLS). The motor had a new fuel pump and carb rebuild kit put on it when I purchased it. The motor runs great but not for very long after it's initial start. It won't run higher than idle without losing prime. I have replaced the gas tank and primer bulb and I have not found any leaks in the fuel line as it is fairly new. Could it be filter, plug or some other part I am over looking?
