Re: alarm sounding
I had this problem with my 1990 suzuki 115hp, many problems followed, first of all replace all sensors, oil, water temp etc. For some reason these sensors in this model is very sensitive, even when you tilt the engine too high on full throttle it would cut out with a limit, or oil warning, but everything is fine. The problem can only be 2 things in your case, the 2 stroke oil and the water flow, this particular model has a sensor by the waterpump, if it doesn't get enough water the alarm will sound. Inside the oil tank is another sensor, which probably gives the most problems. What I did (not the best thing to do) was disconnect all the sensors and just making sure everything is fine and filled up before taking my boat out, no problems after that ....
