Motor rebuilt 2 years ago and hardly used. I have gone through the carbs 2 times in the last year, everything clean and not sticking. I have installed a new fuel pump. Symptoms are very rough idle with a hard miss, sometimes hard enough to make it die. Also, while trying to plane off once given full throttle, it will sometimes bog around like it has no power. Cylinder pressures are good and withing spec. I am convinced this is an electical issue. I have a manual and attempted the pulsar, lighting and primary/secondary coil resistance tests. I am unsure of the readings I got with my multimeter (maybe i'm not using it correctly?). Which of these electronics is the most likely to cause my symptoms. Almost forgot: 1989 Pro50LF - I have removed the oil injection.<br /><br />Thanks for any help guys,<br /><br />Ryan
