Craig Killip
- Mar 14, 2006
- 12
Hi Guys! <br />In a good mood as I am the proud owner of a new toy! <br />The motor on the back is a Yammy 50hp 4stroker (1996).<br />Inevitably I have a few questions already....<br /><br />I'd like to do an oil change, so which oil should I put in? Does it depend on operating conditions? Normal air temp for use is probably 10 degs with a sea temp of similar. However in summer air temp reaches 30 degs - but that's occasional!<br /><br />Next Q. My trim indicator is stuck at one reading (3/4). The sender unit goes up and down ok.....any thoughts?<br /><br />Next Q - probably not a reality, but I have just done a quick search of the forum and saw something about connecting hour counters. If I got an hour counter would it tell me the hours the motor has already done?<br /><br />Final Q. I need to do the impeller and g/box oil. Any special instructions - do I just use the standard Quicksilver outboard g/box stuff?<br /><br />Thanks for reading and thanks in advance for any help you may be able to give!<br /><br />Can't wait for sea trials some time this week! She seems to run Sweeet!
