Re: Temp and Water Pressure Gauge
Regarding temperature gauges. What type of gauge are you looking at? Cylinder head temperature or water temperature. The senders are not the same. How accurate do you think those gauges are? Do they move depending on operation? You see -- you are on both sides of a discussion. I happen to have a temp gauge that reads "C----H" with hash marks at 1/3, 1/2, and 3/4 scale. Where do you think that gauge should read? If you find a gauge calibrated in degrees what should that range be? Just in case you are interested, before you install that temp gauge I suggest you bench calibrate it as unless you do, you will have no idea what temperature the engine is really running at and the temp horn will tell you the engine just cooked about the time your gauge is mid scale. I've calibrated two temp senders in the last couple of weeks. I've checked them in 5 degree increments using a digital thermometer and a digital ohm meter. At any given temperature these two sensors varied all over the map. 15 ohms can mean a 5 to 10 degree error in temperature and that doesn't include any error in the gauge itself. To the defense of the temp gauge, it too provides a "relative" indication of what's going on with the engine. When things vary from the "norm" take heed as something is up. Temp gauge, the pressure gauge, and the tell tale work in unison to provide the data you need to ensure your engine lives long. Bye! All a new water pump every two years proves is that you have a new water pump. Does it work better, worse, or the same as the old one did, or the one before that, or the original. Without a pressure gauge you have no idea.
