wnelson1968
- Feb 27, 2006
- 4
These engines run to well to scrap because of a rusted part but I understand that this is a large project. The engines were in salt water for nine years and fresh water for the last 5 or so. I can see tool marks on the external hardware so I believe they have been removed at least once. This is the only and worst part of rust damage on the assembly. However, one can not recognize nut nor bolt at the base of this arm. My primary consern is busting a bolt that holds the powerhead on. Any help would been great! <br />Also, I need a line a spanner wrench or idea to remove the caps on the tilt and trim. <br />Thanks you<br />Wynn
