danvillemarine
- Feb 25, 2006
- 15
Problem is that #2 cylinder won't fire. Swapped wires from #1 to #2 and coil has fire. New plugs to the engine ran that ran good and then went downhill. The #2 plugs had no carbon and #5 had a little. What is the firing order from the cdi? And what should the pulsar coil? read for ohms. Compression is 100 on all. Where or how do I go from here? Thanks alot...
