This is a 2001 turz efi 2stroke ,but the powerhead is 2004 with 78 hrs on it as of now. This engine sits from April 1 to Nov.1 with a full tank of gas(I'm told it cuts down on condensation in main tank with stabil conditioner).new water/separator, The fuel was drained halfway and replaced with fresh gas for the first trip out,and 15 miles out engine at 4000 rpm quit,restarted and went a mile further with no problem with higher rpm ,went home at 4300 rpm and no problem,next two trips no problem.Yesterday 25 miles out ,running great at 4200rpm ,engine quits with no stuttering,but restarts instantly. Changed water/separator in boat and dumped under engine cover filter with floating red ring that was up as high as it would go while on the water and the engine still cut out after one minute of high rpm .No warning horns but did notice slight speed reduction prior to shut down. Came back at 3000 rpm and not a cut off,run smooth but not on plane,last mile of trip ran 2 miles at 4200 on a 12 gallon of new gas and no problems. Cleaned main tank out and did have some water. any ideas appreciated .Can the shut-downs ruin the engine?
