Hope someone can help - I recently have all the carbs serviced, the vacuum pump replaced, new plugs, because the engine was lossing power at higher RPM.(As if it was running on 2 instead of 3 cylinders. The problem seems to have partly gone. Now the engine runs OK till higher RPM then it misses quite badly. However when you brong the RPM's back slightly it runs perfectly.<br />Have been stared towards the power pack.<br />cheers<br /><br />Jetpro
