Hi,<br /><br />I have an 04 Yamaha 90 2 stroke with 5 hrs on it. When on the lake a couple of days ago the motor would not restart once.<br /><br />I had shut the motor off while in gear prior to this happening, when I would try the key I got nothing, the trim and hour meter and the guages worked, it was just like the motor was not in the loop.<br /><br />After running the trim all the way up and down and around 10 min later, the motor started fine and continued to restart after that.<br /><br />Should I be worried or is there some kind of timeout when you kill the motor while in gear.<br /><br />Thanks for the help<br />Rick
