sonoramike
- Nov 21, 2005
- 32
on the lower unit there is a small rudder flap that looks to be adjustable and probably has something to do with the steering. not sure what its for or how to adjust it (or even what its called). right now its set all the way to the drivers side, how do I realign it and what sort of effect should it have? I've tried moving it by hand but it won't budge, didn't see a jam nut anywhere for it so I'm stumped.<br /><br />And the tiny little port in the lower unit for the speedo, its blocked up and I'm only able to get a small piece of wire into the hole about 1/4" or so, how far back does the port go before it turns upward? thinking that working a small drill bit by hand in the hole would help clean it up, but don't want to cause damage...<br /><br />any help greatly appreciated
