summers1996
- Nov 2, 2005
- 30
Hey there, new to the forum. I have seen this before but havent seen the fix. While running on plane my DT55 dropped power and runs about 3000 rpm. Now it will not run above that. RPMs are fine out of the water and not under a load. I do have the owners manual. I replaced my oil filter and that wasnt it. The oil pump seems to be pumping fine. Oil level is also fine and the oil level light shows the same. I tried to reset the oil level reset switch (on the side of the engine). It doesnt budge. I replaced the water pump. Still same problem...BUT I noticed that the tell tale is not producing a steady stream. It doesnt seem to be overheating. The red water light comes on when I start the engine and the alarm has a steady buzz and then shuts off. <br /><br />Q 1: Will the water/coolant sensor cause the lower rpm?<br /><br />Q 2: If so, is there a reset switch? I cannot find one and the manual doesnt mention one for this model.<br /><br />Q 3: is there a particular place in the coolant lines that this engine typicaly clogs?<br /><br />Q 4: If it was originally an oil problem and I have a bad reset switch. Can I "jump" the oil level reset switch to reset the system?<br /><br />Q 5: Does the engine need to be running to reset any of these systems?<br /><br />Other notes: 1998 DT55 with a jet drive pump, 17 ft aluminum simi V. Engine runs smooth and starts fine.<br /> <br />Help, <br />Up a creek without power.<br /><br />Neil
