Hi again,<br />Today I noticed that my new Double Eagle with my /93 65HP Johnson has perhaps some motor mounting problems.<br /><br />On the old Fiberform boat, the motor sat right on the transom, and now the motor sits about 3/4 of an inch above the transom. There is one hole left to use. The distance from top of transom to bottom of keel is now about 1/2 inch longer than on the Fiberform.<br /><br />The position of the cavitation plate is now about 3/4 of an inch above the keel. Should it not be even with the keel or even just below, or am I OK with the way it is mounted now?<br /><br />thanks again for your help<br />Mike
