mulliganmagic
- Jan 9, 2004
- 82
I had a big problem today when installing my smart tabs. I sealed it with the sealent foam tape and 3M 4200. The instructions said to drill 1/8" pilot holes and I think I may have misread it. However, that's what I did and when I tightened the first screw it seemd a little tight. So, I switched from a phillips screw driver to a 1/4" ratchet with a phillips bit. I began to become worried and removed all of the screws except for the last one which actually broke upon removing it. I tried to use vice grips and channel locks and even tried to drill the screw out, but that hardened steel simply will not budge. I think or at least hope that it is sealed, but I worry that it might not be. So I now come to the point of installing the smart tabs. What can I do? Any help is appriciated.
