Karl Sheasby
- Jun 17, 2004
- 5
I have a 85 Yamaha that is overheating. The engine was built in 1991. The ports in the engine are clogged with salt etc. like cement. The engine only overheats in the middle of summer. I changed the water pump and thermostats at the end of last summer. No problems last winter. The water is now near 90 degrees and the engine is over heating again. If I run at 4000 rpms the engine will not over heat. I cruise at 4800 rpms and never above. I don't want to remove the covers and break bolts. Can I remove the thermostats in the summer and replace when winter comes.<br /><br />Regards
