1989 Yamaha 9.9 . I removed and cleaned carb . There were flakes in bowl and debris on main jet intrance .Thought I had it licked . Same thing . Starts fine , idles evan at fast idle fine . Put in gear and runs fine till I start to open it up and then dies . Pumping fuel ball does nothing . Pulled fuel pump and checked for diaphram leakage and checkvalve ops ok . Replaced fuel line with clear from fuel filter to carb so I could watch . There is always a 2 inch section filled with air at bottom of loop before carb intake . Haven't checked valve adjustment yet and plan to do compression check next . Flywheel seems hard to turn by hand with spark plugs removed , although I don't know how it should feel . My fear is the engine has been running too lean with partially plugged main jet and caused powerhead damage .Thanks in advance for suggestions .<br />Cap'n One Aye
