Re: Suzuki 85 hp ignition problem
domilex,<br />1996 DT85, well that is not an old outboard. Must get that running quick now I guess. You have vacation now? And want to use the boat/outboard during this period.<br /><br />So:<br />1. You have good spark on all sparkplugs - right?<br />and sparkplug cables not faulty?<br />2. You have correct and functional sparkplugs?<br />(Use only NKG BR8HS-10, gap 0.9-1.0 mm, for a DT85 1996)<br />3. Have the compression on all 3 cyl been tested?<br />About same psi (compression) on all cylinders?<br />4. Fuelpump OK? (the rubber diaphgram set)<br />5. Battery OK and connections tight and have proper contact at battery and at the outboard itself?<br />6. Have You gone over all electrical connections to make sure no bad contact somewhere?<br /><br />Is there any alarm going on when You try to run the outboard?<br /><br />Do You have access to an electrical scheme for Your DT85 1996? I can probably mail one to You if You think that will help You.<br /><br />I ask this since that is some of the basic things You must know is OK before trying anything else.<br /><br />If we assume 1-6 above is OK, then it can be many things that can be the cause to the problem Your outboard has today.<br /><br />In a trouble shooting table I have here, for missfire they suggest for example:<br /><br />Missfire at idle:<br />- Incorrect spark plug gap<br />- Defective, dirty or loose spark plugs<br />- Spark plugs of incorrect heat range<br />(- Cracked distributor cap)<br />- Leaking or broken high tension wires<br />- Weak magnets<br />- Defective coils or condenser<br />- Defective ignition switch<br />- Spark timing out of adjustment<br /><br />Missfires at high speed:<br />- Se above<br />- Coil breaks down (too high voltage, excessive heat, moisture)<br />- Coil shorts trough insulation<br />- Spark plug gap too wide<br />- To much spark advance<br /><br />Not sure if You can describe the problem with Your outboard as "rough operation", but if it is it can be like:<br />- Dirt or water in fuel<br />- Reed valve broken<br />- Float stuck<br />- Incorrect fuel level in carburator bowl<br />- Carburator loose at mounting point<br /><br />If carburator spit-back(?) and missfires at high speed it could be:<br />- Reed valve broken<br />- Dirty carburator<br />- Lean carburator adjustment<br />- Restriction in fuel system<br />- Low fuel pump pressure<br /><br />Do You have access to multimeter so You can test voltage and ohm?<br /><br />You can then perform tests on many components of electrical system.<br />I can maybe mail You some files that tell what and how to test.
