Runs but without power. Pull plugs after a run and they are wet and black. Plugs, carbs and fuel pump are new also. Engine run in lake on trailer, timing steady and at proper advance on all three cylinders. Ohms of coils under flywheel are in spec of Seloc manual. Starts getting way out of spec on coils as primary side is in range but secondary side tests open on my digital meter. Is this the problem even thou spark is showing at each plug?
