muskrat
- Apr 13, 2004
- 445
When motor is up to operation temp,it wants to start cutting out intermittly.Sometimes cuts out completely,somtimes it acts like it wants to cut out.A couple thing I tried,when you unplug main ignition with engine running it cutts out.Ohm crank sensor in spec.Going to clean all grounds.What size battery should this motor be running.thanks
