Re: dt85 heat sensor
Hi,<br /><br />It is<br /><br />- Water level switch (it looks like a clothespeg or similar). On older Suzuki I belive.<br /><br />OR<br /><br />- Heat sensing switch (it is round). On newer Suzuki if I'm not misstaken.<br /><br />Assuming it is an overheat alarm??:<br /><br />When You run the engine, how hot does it get? Run without cowl so You can place Your hand on cylinderhead and You should be able to keep Your hand on it. So not as hot so You need to remove your hand (to not get burned). I belive there are heat stickers you can glue on the cyl head to see temp also (I do not know where to buy).<br /><br />Make sure the water tube that goes from waterpump up to powerhead has the grommets correctly seated in both ends of the tube. I had a Suzuki DT65 before and when changing waterpump (impeller) I also changed to new rubber grommets on that water tube.<br /><br />Also, the alarm: is it really overheat alarm going on? Ask your friend again and check the Owners manual what alarm is going on.<br /><br />If it is overheat alarm going on it can also be obstruction in water cooling channels. It is possible to flush the channels in reverse direction but you should remove the lower unit then.<br /><br />Is this outboard used in saltwater?<br />If Yes, it could be salt built up inside the outboard cooling channels restricting water flow, asuming it is an overheat (alarm) situation we have here.<br /><br />How long can be outboard be running and at what RPM before the ??? alarm goes on?
