Fishhead-1
- Oct 10, 2003
- 110
Been reading board for a few years,thanks Rod Bolt have learned a few things.Finally have a problem I havent seen posted.DT 225 oil injected,fuel injected,2 plugs per cylinder,Cold start excessive smoke,dosent run rough,but clears up after a couple minutes.Dosent smoke at all after that.Very low hours on engine.Been to dealer for problem,no available answers.Between oil injector pump and intake is somthing that looks like check valves,are they? and could they be leaking by during overnight.I de carb once a year and runs great and starts unbelievable quick.Thanks again for you guys. Fishhead
