I recently purchased my first boat, Cobia 194 with a 1998 Yamaha 150 outboard. Its a V6, premix, and is carbureted. I have never owned an outboard before so have very little knowledge of making repairs or spotting problems but am hoping to learn
<br /><br />The engine runs well but I often stall it out a few times initially trying to get it started when its cold, I attribute this mainly to being unfamiliar with the engine and probably not knowing the best routine for starting. Once it is warmed up it starts right up. Usually after initially trying to get it started (and having it stall out a few times) I notice a small amount of fuel (maybe a soda cap full or a bit more) has leaked into the bottom pan of the engine and then to the transom. Once its running it does not continue to leak. <br /><br />Is this unusual and would it indicate any particular kind of problem? One thing I should add is when initially starting the engine I have been leaving it partially trimd up though down enough to have the prop and water intake in the water. I was told that this could cause the carbs to leak? Will try starting it next weekend with the engine fully down to see if it still leaks.
