  #1
Old August 26th, 2005, 02:57 PM
DeanPA DeanPA is offline
Default Cavitation problem, O/B pontoon boat
Hi all, I recently bought a good used 1996 Harris 24' pontoon (my third boat) for use on a lake in PA, where we weekend.The boat came with a Force 75HP, Model 75ELPT, which was professionally maintained (former owner was a very straight-up 75 year old gentleman) and obviously not abused. The mechanic near me in PA does not know the guy nor the boat, and said he could find nothing wrong with the boat or motor.Other than an instance where the engine lost prime (mech. told me the Force outboards have a tiny fuel pump, and will occasionally do that after running at constant speed for a long period) it has run perfectly for the 10-15 hours we put on it this beautiful summer at the Lake (Wallenpaupack)----BUT------I think I may have the wrong prop on. Specs call for WOT at 4750-5250 RPM. I am at about 4700, but when I run at any speed above 2500 for any length of time, I get cavitation eventually, especially in a slight chop. Even in fairly calm water, it'll eventually lose its bite. If I lean over the stern and look while running (wife driving!!!) I can see the path of bubbly water trailing astern. Acts like a car with a slipping clutch until I back it down to 1500 or so. Also, the motor has Power Trim, but forget running at any trim other than full down.I was in the water last week, trimmed the motor up all the way and gave the prop a good look. It's mint, there isn't so much as a ding in it, and the lower unit is just as clean.The prop bears a number very close to:48-73133 A40 13PCould have been 73113, but no pencil on board.A friend, retired marine mechanic, who lives in NC and hasn't seen the boat, had told me a cupped prop might be the answer, but from researching the part number, it appears the prop on the boat may already be cupped (I couldn't tell).I am certainly not going to start buying props of different sizes willy-nilly just to "try" them out, and could probably use a little education in this prop selection business.Oh, by the way, the motor's mounted as far down as it will go. (top set of mounting holes).Help. Thanks,Dean
  #2
Old August 26th, 2005, 06:55 PM
Navigator Navigator is offline
Default Re: Cavitation problem, O/B pontoon boat
Dean,Is the motor the correct shaft length for the boat?It kind of sounds like you have a long shaft mounted where an Extra-Long shaft is required. Can you see where the anti-ventilation plate sits when running? Also, does the sound decrease when you lean over the stern (this gives more weight to the rear and pushes the prop deeper) It it was cavitating, you would be hearing exhauset sounds aswell as the regular engine sounds.Nav
  #3
Old August 26th, 2005, 08:28 PM
Nav, The ventilation plate sits just about flush with the surface of the water while running---MAYBE an inch or so under, can't remember exactly.The motor is a 75ELPT---I am assuming that means "Extra Long, Power Trim", maybe I'm wrong on that. The motor was original equipment with the boat when new, and that's documented. I realize that new pontoon boats ship without motors, and perhaps dealers throw whatever motor they have a surplus of on the boat, but I find it hard to believe the boat has had this problem since new. In person, I'm a fair judge of character, and this fellow would have told me about it for sure, although he did say that his son did most of the driving while taking the grandchildren out on the lake, so perhaps it was always a problem, and the seller wasn't even aware of it. Maybe they just accepted the problem and didn't think about it.OTOH, this prop looks almost, if not brand new, so I'm wondering if it was a recent replacement.And if so, what did it replace?But more importantly, what now?Dean
  #4
Old August 26th, 2005, 09:47 PM
AMD Rules's Avatar
AMD Rules AMD Rules is offline
E = Electric StartL = Long Shaft (20")PT = Power Tilt/TrimHave you examined the weight distribution? (Wondering if it is possible that you have a bow-heavy situation thus lifting the stern)
__________________
'72 Glastron GT160 c/w '72, '84 and '86 Merc 115hp
'67 Merc 3.9hp , '70 Merc 9.8hp, '61 Merc 50hp ... The Merc Nut
  #5
Old August 27th, 2005, 01:26 PM
steelespike steelespike is offline
Im pretty sure most marinas will let you try props to find the right one.I'm no prop expertbut cupping should help and I think possibly 4 blades.There is a chance that your newer Force may use a Merc prop.Just speculation I don't really have a clue.Other than they did use more Merc stuff as time went on.Also do check your weight distribution.Moving just one person might solve your problem.Movimg 100 lbs from bow to stern is like a 200 lb change.
  #6
Old August 28th, 2005, 06:20 AM
I'm pretty sure weight isn't the problem. Shows the problem the same with two aboard seated in back, and six aboard distributed all around the boat.Yeah, it's a Merc part number on the prop. The motor is labeled "Force---by Mercury Marine", and the lower unit bears a very close resemblance to a Merc, might even be a Merc lower unit.AMD: in regards to the translation of "ELPT"....any ideal if they made an "Extra Long" (longer than 20") shaft model ?The idea of trying different props out is a great one, I'll start asking around my local marinas.Where should the AV plate be while running?
  #7
Old August 28th, 2005, 03:53 PM
Dunaruna's Avatar
Dunaruna Dunaruna is offline
Send a message via Skype™ to Dunaruna
I had a similar problem, motor had to go down another 2 inches - problem fixed.It's difficult to find the correct position of the AV plate on a toon boat because there is no hull to use as a reference.Triple check that prop number, the only number that is close (that I can find) is 48-73138a40 and that is a force part number (10 1/4" x 14"), designed for light loads.Aldo
__________________
Watch this space......................
  #8
Old August 28th, 2005, 07:54 PM
Aldo, Thank you. I'm kind of afraid of that.The number could possibly be 73138 (I was treading water while I read it) but it ends in "A40 13P". Would that be a 13 pitch?I guess if I need an Extra Long, but only have a Long, I'll have to live with it. Just trying to figure out what I can do to mitigate the problem.How the heck could I lower the motor.....???
  #9
Old August 28th, 2005, 10:31 PM
Dunaruna's Avatar
With mine, I had to modify the mounting beam.How much of the toons are underwater? 50%?
__________________
  #10
Old August 29th, 2005, 04:53 AM
I would say the pontoons are slightly less than half in the water.I don't know what the terminology is, but the transom is the back of an aluminum structure underneath the stern. The structure looks kind of like the bow of a rowboat, and is bolted to the frame.From a practical viewpoint, I can see how I could unbolt the structure from the frame, put spacers between, and bolt it back up, but putting that structure closer to the waterline (and perhaps IN the water) would no doubt have an adverse effect on my profile in the water. No one responded in regard to whether Force made a longer shaft motor than the one I have. I'd like to know if it's possible to swap lower units. Probably a headache, though..
  #11
Old August 29th, 2005, 02:27 PM
CharlesW CharlesW is offline
Location: Ankeny, Iowa, Sun Valley Lake, Iowa whenever possible:)
Quote:
Originally posted by DeanPA:The ventilation plate sits just about flush with the surface of the water while running---MAYBE an inch or so under, can't remember exactly.Dean
While I'm certainly no expert, that sounds like the motor is too high.On my pontoon boat, the cavitation plate is about even with the bottom of my pontoons.On my Chris Craft, it is about even with the bottom of the boat.In both cases, this puts the cavitation plate about 6" under the water. Possibly even as much as 10" when at rest.
  #12
Old August 29th, 2005, 02:55 PM
BillP BillP is offline
Location: Recently moved to high rise waterfront condo on Pluto. What a view!
Your're not alone. My pontoon boat does it when running wide open with people in the bow. It's a plague of pontoon boats and why merc invented "Big Foot" motors. Standard props are pitched too steep for the slow speeds (20-25mph at full throttle)and they run on the edge of cavitation. All it takes is a little wave action or loading heavy and the problem gets worse. Running the motor deeper will help but this isn't ventillation so deeper doesn't make a big difference unless the motor is way high in the first place. The best fix is dialing in the engine with a large diameter prop with lower pitch for max rpm.
  #13
Old August 30th, 2005, 07:25 PM
Please bear with me, I think a lot better in car terms when it comes to pitch.The last characters on my prop are "13P", is it too big a jump in logic to assume this is a 13 pitch prop?Now---me trying to get some perspective on how pitch is numbered----a lower pitch number is less pitch? ----and less pitch means the prop blade slices less of a profile through the water? ---and this would equate to HIGHER gearing in a car?-----so in car terms, I need to go to higher "gearing", which will give me more top end but cost me some hole shot pull?I think I have something backward...but what?
  #14
Old August 30th, 2005, 08:48 PM
Dunaruna's Avatar
I also think you have a 13" pitch.Your gearing analogy is good but you need to use your WOT RPMs' as a guide, less pitch will increase your maximum RPM's which could be very bad. More pitch will decrease you WOT RPMs' which can cause lugging, also bad.Usually, less pitch will give better holeshot (is that what you want in a toon boat?) and top end will suffer.[Quote by BillP:"The best fix is dialing in the engine with a large diameter prop with lower pitch for max rpm." ]Makes a lot of sense to me. I'm currently running a 14 x 9.Aldo
__________________
  #15
Old August 31st, 2005, 02:24 PM
OK, so your 14 X 9 has a larger diameter and less pitch than my prop.Any way of knowing if this size prop would fit on my Force O/B ?I'm going up to the Lake this weekend. Have to check with the marina and see if they have any props I can try out.Thanks again.
  #16
Old August 31st, 2005, 03:37 PM
Dunaruna's Avatar
I should explain, my boat is totally different to yours, i also run a different motor. The 14 x 9 suits my package nicely, it may not suit yours.In your case, you need to experiment - beg/borrow props and test them. Some prop shops will lend them to you if you agree to eventually purchase through them. You have a starting reference prop - work from there.I have a 50hp efi bigfoot pushing a 12 ton houseboat.Aldo
__________________
  #17
Old September 5th, 2005, 12:40 PM
Well, back from the Lake. I figured out the problem. Good News/ Bad News. Solving it will be another story.We went out with 7 people. I seated 5 of them in the stern, and ran it wide open. No problem at all. WOT was about 4600, close enough. I made sharp turns and everything---motor never missed a beat.That's the good news.Now all I have to do is figure out how to get another 2-3 inches of motor into the water.Somebody mentioned an extension kit for lower units---anybody know anything about these?Another idea is to unbolt the transom unit and put spacers between it and the frame. Would that work?
  #18
Old September 5th, 2005, 12:48 PM
It seems unlikely that you don't have some adjustment for motor height presently.You have no doubt checked and are sure it can't be lowered any, right?
  #19
Old September 5th, 2005, 01:11 PM
shebe3 shebe3 is offline
You and some of the members are calling your problem cavitation. I think your problem is ventilation. If your prop was cavitating badly it would not take to much time and your prop would not look like new. Cavitation generates some distructive forces on the surface of the prop and will remove paint and metal in a short time.
  #20
Old September 5th, 2005, 02:11 PM
Charles, The motor is mounted in the top holes in the mounting bracket, and the motor bracket is right on top of the transom.Short of a motor with a longer lower unit, extending my existing lower unit (if possible????)or lowering the transom, I don't know what else I could do.Shebe, thank you for the correction. My prop looks great, so perhaps it is ventilation and not cavitation as I stated.
  #21
Old September 5th, 2005, 03:13 PM
Quote:
Originally posted by DeanPA: Charles, The motor is mounted in the top holes in the mounting bracket, and the motor bracket is right on top of the transom.Short of a motor with a longer lower unit, extending my existing lower unit (if possible????)or lowering the transom, I don't know what else I could do.Shebe, thank you for the correction. My prop looks great, so perhaps it is ventilation and not cavitation as I stated.
It sounds like you have covered all the bases.It just seemed really strange that a manufacturer would set up a motor pod that mounts a motor too high and no adjustment can be made.Where is the anti-ventilation plate in relation to the water and the bottom of your pontoons when the boat is at rest?
  #22
Old September 5th, 2005, 08:46 PM
Can't remember accurately enough to answer that, Charles.How would I go about finding out if the Force 75ELPT was a recommended motor for my boat?----And is it possible the wrong motor pod was installed at the factory?----And would it be a huge deal to replace the motor pod? Where does one go about finding a replacement?
  #23
Old September 5th, 2005, 09:15 PM
Probably the best source of answers to your questions would be the people that made the boat.Try this link .
  #24
Old September 6th, 2005, 05:27 PM
Earlier, I got off the phone with "Bob" at Harris-Kayot. A real gentleman. Even though my boat was bought second-hand and is almost 10 years old, he took a sincere interest in my problem.Bottom line, he suggested two solutions:1/ Install a "StingRay" type of stabilizer on the motor. Bob felt that stood a very good chance of eliminating the problem, and/or2/ Lowering the motor pod by use of spacers. He said this problem is unusual but not unheard-of, and the installation of spacers (he recommended NOT to go more than 1 1/2 inches) was acceptable from Harris' standpoint (not that I'm worried about the warranty or anything, I just didn't want to do anything beyond the pale). Bob went on to answer a question about the nose of the motor pod "plowing" through the water by saying the pod is designed to do that. He even offered to check around the plant to see if they have anything that could be used as spacers "lying around".Wow, was I impressed.Anyhow, since I am only up at the Lake on weekends, and the boat has to be on dry land by the beginning of October or so, I doubt I will be undertaking any major projects until it comes out.I thank everyone for their comments, and if I discover anything that works, I'll come back to this post and "bump" it upwards.
  #25
Old September 10th, 2005, 05:45 AM
Update:I have just ordered a set of lowering blocks from Bob at Harris. $50 for six aluminum blocks plus the longer stainless bolts I'll need to install them.When I asked Bob when Harris actually uses these blocks, he told me they use them to mount the motor pod when a "non-Bigfoot" motor is intended to be installed, or boats with the 25" tubes.I don't know a lot about Bigfoot motors, other than that they are extra-long-shaft motors made by Merc, supposedly for pontoon boats with the larger-diameter tubes, so that makes sense.In any case, this should get me another 1.5 to 2 inches of lower unit in the water, which probably couldn't hurt.Thanks for the advice about contacting the manufacturer. I guess I'm used to non-boating product lines, where a 10-year-old item, purchased used, is of no interest whatsoever to the original maker.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Cavitation plate height on pontoon boat? bullseye422 Non-Repair Outboard Discussions 1 March 19th, 2006 10:19 AM
New boat Cavitation problem 30-A rider Johnson & Evinrude Outboards 1 September 3rd, 2005 08:14 AM
pontoon cavitation Dirty Worm Boat Topics and Questions (not engine topics) 1 June 30th, 2004 07:10 PM
cavitation/ventilation problem pontoon boat RCTJohnson Mercury & Mariner Outboards 9 June 10th, 2003 06:28 PM
Pontoon boat cavitation & Vibration Pessemist Non-Repair Outboard Discussions 14 September 17th, 2002 02:39 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
