Re: Installing Tach
Is it the digital or analogue?<br /><br />I have a old version of the owners manuall for my yam 90 2-stroke. It describes how to change the setting of the Tach.<br /><br />I recently bought a new (used) set of instruments. They came from a F50, 2002. I follow the direction and it worked so I guess it will work for you as well.<br /><br />On the back of the tach there is a setting device.<br />On the digital one there is cap that has to be romeved to get to a set of switches. The left one isn't used. The right one swithes between 6 and 12 pole. (up is 6 pole, down is 12 pole, 80-90 hp and V4/V6 engines are 12 pole)<br /><br />On the analoue there is cap hiding a dial selector. Set the dial to 12, 6 or 4 pole (12 poles are 80-90 hp and V4/V6 engines, 6 pole are 40-70 hp, 4 pole is 40Q-55B)<br /><br />Hope this helps...
