Putting a 2001 Yamy 115 where I had an '83 Johnson 140. The steering is a simple teleflex system. Will the teleflex bolt right on to the Yamy bracket or is it different than the OMC connection? Thanks
The only difference should be the link arm from the cable to the motor. Not that the link arm hooks to the inner bolt hole on the steering arm, not the outer one.
