I have 2 of these outboards and this weekend I cleaned both sensors using the methods described in this forum. Although I didn't have a test harness, I soldered 2 test wires on each O2 sensor so I could read the voltage (across the black and grey wires). Once warming up they both settled in around 0.5v to 0.6v. When I plugged the top cyl throttle plate hole they only changed from, say 0.52v to 0.59v ... and when I unplugged the hole it swung to 0.50v and then selled in on 0.52v. From what I had read in the testing descriptions I was expecting a much larger voltage swing. Does this indicate I have 2 bad O2 sensors?
