Re: Internal fuel tank gauge & panel gauge synchronization
Not being an expert on the topic I tell you what I know and can guess (I have a degree in engineering).<br /><br />- I don't use the fuel meter my self, I have three seperate fueltanks that is easier to get to the gas station for my type of boating.<br /><br />- To your question, boths the tach and the speedo meter has switches. I only seen some old info about the function of the one at the Tach, it has to be set according to the size of the engine to get correct rpm reading, different engines give different number of pulses per revolution.<br /><br />- I have searched Yamaha for the function of the switch and posted the question on some forums like this, no one had a clue (no answers than let them be).<br /><br />- The fuel senders are typical a rod with a float running up and down. Depending on the postion of the float you get different resistans from the sender. So let's say that you got the "correct" sender for your instrument, the max and min resistance corresponds to what your instrumnet when you have it dismounted.<br />But when the sender is mounted in the tank you ge too low readings, it says to me that the mouting postion of the sender isn't optimal, it sits to high. You could adress this with just adding a resistor, but that might prevent you from having a Zero reading.<br /><br />If the shape of your tank was very odd (Wide in the top and narrow in the bottom) you could have correct reading on max and min but the half tank reading could be given even though the tank was nearly empty, if you understand what I mean.<br />This is very hard to correct, you need the variable ristance to match the geometry of your tank, some car manufactures do this either "electronic" in the cpu or with some special resistors.<br /><br />-I would guess that "playing" with the switches doesn't harm your instrument, so just take a note of the original postions for the switches. Then try different settings and move the fuel sender in different positions to see if the behavior is changeing. I would be intressted in your findings...<br /><br />Good luck
