  #1
Old April 7th, 2006, 06:07 PM
nscrnt8 nscrnt8 is offline
Default new to me toon owner
hey ya-all, we just purchased a 01 22' crest fisherman dl toon. to me i think its in excellent shape, the carpet doesnt show any abnormal wear , all the seats are in good condition with no tears or cracks. the deck is solid though out and the underside shows no sign of rot. the wind screen at the drivers console is a bit faded and shows signs of sun cracking. all the railing and panels are in good shape, has a dent in left side rear panel and its missing one of the trim pieces at that corner that covers the deck( nothing major just a slight woops) it came with 3 life vests a huge saftey kit ( havent opened it yet but its the size of a suitcase) 2 deep cycle batts a garmin fishfinder and some other odd and ends rope anchor bumpers. it has a merc 90 fourstroke hung on the back that looks like new, but in doing some cylinder test it appears it may need a valve job. im thinking it may just be carbon build up and needs to be run to burn it off . note: the hour meter on the dash sais 846 but the motor appears not to be the original, the oil filter sias 60 and the mounting holes have wear on them like it mounted on something else and the date code is 1 year off to the date of mfg of the boat. this is my biggest worry but im going to do general maintinence on it and give it a run and retest it.tommorow i figurer on spending about 250.00 on new spark plug wires( the ends of the others are corroded) set of spark plugs, oil , oil filter, new bottom end oil ( im sure thats not the correct term but the oil down at the prop), and a service manual , so i know what im doing. it also came with a perfomance tandem axle trailer that is in decent shape. in the process of putting all new springs and new complete hubs on it at a cost of 200.00. anyway here are the questions: i paid 5200, just a tad over 6 with tax and all out the door for the package. good no good? "about" how fast will it go. will that motor be strong enough to pull a tube, or be able to water ski behind? i dont know the size of the fuel tank ( and i know it depends on how much you keep your hand in it) but how much fuel will it burn??? how will it handle ??? ive been on a single hull design 21' i/o volvo a trihull 18' o/b 50merc and a 19' toon 50 merc. to just try and give some comparison.ive have read some threads about putting sheilds/plates on the bottom, is this a good option ??? weight versus performance??? i will be in the rivers all the time and it can/does get choppy at times. my fuel tank is on the bottom/ underside and appears to to make a nice "V" down to the prop. ok i guess that about it for now, i know i get a bit long in the fingers when i type sorry about that. joe
  #2
Old April 7th, 2006, 09:05 PM
beezee28 beezee28 is offline
Default Re: new to me toon owner
Welcome to iboats.
  #3
Old April 7th, 2006, 09:26 PM
roscoe's Avatar
roscoe roscoe is offline
Sounds good to me, as long as the motor checks out.I really can't help you with your performance questions, but welcome to the party.
  #4
Old April 8th, 2006, 01:59 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Hi nscrnt8 To answer a couple of questions from experience, sounds like you got a great deal for the money. Very well built toon. You should be able to hit 25 MPH or so with that set-up and pull a tube with no problem. Might get a light skier up with only 2 aboard. Probably burn 4-6 gallons per hour wide open. It will handle slow, like most pontoons. Slow to turn and such, but will ride very nice and dry in the chop. Skinning the bottom would be a good idea if you run rough water. Stops the waves from slapping the crossmembers and gives you better speed(More consistant). Try posting over in the site below. Good folks over there, too. I'm there often checking out the pontoon forum.....Copy and paste the URL and good luck with the new toon.... harrispublishing.com/fusetalk/forum/index.cfm?forumid=3
__________________
Rick
"Boating is Life...All the rest is just Details"
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
A 3rd Toon, Perhaps?!?!? Kmestep Boat Topics and Questions (not engine topics) 8 April 24th, 2006 08:56 AM
Buying a toon jason176 Boat Topics and Questions (not engine topics) 34 February 27th, 2006 07:09 AM
14' toon or any toons one more cast Boat Topics and Questions (not engine topics) 6 February 15th, 2005 03:15 AM
Toon Tyme 10-21-03 LadyFish Dockside Chat 5 October 21st, 2003 11:02 PM
Toon Tyme LadyFish Dockside Chat 8 August 14th, 2003 06:57 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
