Re: Shift / throtle linkage adjustment
Finally tried this - something is wrong. If I put the engine in real neutral, and then disconnect the linkage and then put the control box in 12 o'clock position, there isn't enough thread depth inside the trunion for as far as I need to screw in the cable (looks like neutral is not in the center of the slider). I switched the trunions between the throttle and the shifter since they were not the same size and I could get the shifter a little closer to where it wanted to go (and the throttle had plenty of thread on either side of the locknut, so it is not an issue here).<br /><br />It is somewhat better now, although not perfect - at least in the 12 o'clock position is is no longer in reverse.<br /><br />But I am concerned that I do have a shift shaft problem since this was right for the first 10 years of the engine's life.
