Just bought 1988 Yamaha 130 hp. I bought it knowing there was something wrong with it (not running right) It has a Yamaha 703 control which I think I know how to use bit not sure. Here is where Im at so far.<br /><br />Good news: compression is 135 -145 all four cylinders , this is good right?<br /><br />I did manage to get it running but it only seems to keep running if I have the high idle arm up quit a bit and keep hitting the high idle switch. When it revs it sounds pretty good and seems to be running on all cylinders.<br /><br />Gas could be old or bad and filter could be crappy.<br />It seems like it starving for fuel. I need to pump the ball a lot.<br /><br />Perhaps I should hook a separate fuel tank with fresh fuel and see what happens.<br />Any other ideas, is this a good start to start eliminating things?
