chadchessher
- Apr 19, 2005
- 11
Hello, I have a 1998 suzuki 150 electronic fuel enjected, and oil injected. It seems to do really well on high rpms and mid rpms. It also evens idles well, But as soon as I put it in gear about 15 minutes later the overheat buzzer sounds. Ive replaced impellar and even checked the thermostats, and they are opening and closing. the telltale water pressure is pretty good, but motors seems to idle little rough when in gear and water telltale shoots good and when motor gets little rough it slacks up. Its not to bad though it dosent stall. Somepeople told me maybe heat sensors, is there a way to check these. I dont think suzuki has a pressure control valve or popet valve do they. Thanks for the help hope to hear from you.
